Put my Hot Seat Exhaust on---Questions?????
Old Apr 25, 2005 | 07:33 PM
SuckMyMuffler's Avatar
Default Put my Hot Seat Exhaust on---Questions?????
Where the silencer goes into the pipe where you have to put the donut gasket in.. should that be really tight in there and flush all around the opening? Because when I installed mine the donut shows a little more on one side and the exhaust is fit pretty tight but it doesn't seem to be as tight as it could be.
Old Apr 25, 2005 | 08:14 PM
2manytoys's Avatar
What kind of performance gains did you get? Is it worth it?
Old Apr 25, 2005 | 08:35 PM
XtremeSkier's Avatar
yeah the gasket shouldnt go all the way in..with my scrambler it does the same things, as long as theres not exhuast leaking and uve got it bolted down tight ur alright
Old Apr 26, 2005 | 10:59 AM
Speedwerx's Avatar
The straighter the grafoil donut lines up with silencer the better. By no means should there be a huge amount of the donut showing on one side and nothing on the other, we use the donut because it give us a good seal and a little bit of play when mounting the pipe to the muffler. It not a bad idea to put some high temp silicone on all of the conecting points of the exhaust to prevent minor leaks.
Old Apr 26, 2005 | 05:17 PM
modquad's Avatar
Now isn't that slick. Ask a product question, and the actual manufacturer comes on-line to give you the answer. Cool deal Jeremy! [img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 26, 2005 | 06:00 PM
Thanks Jeremy. No there isn't a significant amount of the donut gasket on one side more than the other. Just a bit and the whole setup isn't REALLY tight, its somewhat loose but isn't that bad. Just wondering if there should be a little looseness on the whole system.
Old Apr 27, 2005 | 11:29 AM
Speedwerx's Avatar
I'm assuming that you should be fine we have had o problems with any of our 325 pipes, its hard to say your opinion of loose and mine might be 2 different things. Too bad you arn't closer to us we woud be glad to take a look at it or you but I think you should be fine run it
Old Apr 27, 2005 | 03:12 PM
ScramblerMan24's Avatar
i cant get my jetting right. right now im at sea level in 70 degrees w/ 260mj and 30 pj with mods below
it has no power 1/8-3/4 until thw rpm's get of the flaaaaaaatttttt spot correction bit flat spot. the needle clip is also stock. the part that throws me is it seams rich ( smokey on bottom ) but runs hot mid range if i don't change throttle positon and just cruise the trails help me before my last payment in 3 months and my wifey gets it when i get a new predator.
Old Apr 27, 2005 | 04:36 PM
Hotdogmb's Avatar
[img]i/expressions/face-icon-small-wink.gif[/img] You may have to look into a Dyno-Jet jet kit. From what i see here, most guys that run a pipe run one of these kits.
Bonzhonda300ex
Sep 17, 2015 10:44 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Sep 10, 2015 01:56 AM
