03' Sp700 no spark
Old Apr 25, 2005 | 10:45 PM
fatduane1's Avatar
Default 03' Sp700 no spark
I have an 03' sp700 twin, nothing but a freakin' lemon!!! One thing after another, but anyway......I recently had an episode where my sprakplug wires actually came off at the same time while riding through a field. I snapped them back on, but they came right off a mile later. Then I replaced them, and guess what???? No spark......I replace the Ignition controller (CDI) and guess what, no spark!!!! After 20 minutes trying to turn it over, and checking grounds, wires and switches, it decides, it's gonna start.......Anybody had this issue yet?
Old Apr 25, 2005 | 11:00 PM
BIGCHEVROLET's Avatar
sorry to tell you man but i had the same problem i was riding down the trail and it quit like someone shut the fuel off.....towed her home and checked the spark....no spark luckily we had the extended warranty so brought it to the dealer and that was it...turned out to be a bad stator.........sorry man
Old Apr 25, 2005 | 11:06 PM
fatduane1's Avatar
Did it start back up at anytime before you replaced it? Mine wouldn't spark, then it would, then it wouldn't again......It has power into the Ignition controller, but no spark out to the plugs......
Old Apr 25, 2005 | 11:33 PM
so it has power to the cdi box?? mine quit let it sit the first time and then it started and worked for about a week then it quit and woudnt go again
Old Apr 26, 2005 | 07:10 AM
fatduane1's Avatar
Yes, it has power to the box. I turn the key to start it, and with a test light, you can see the bright pulsating flash of the light as the flywheel turns trying to start, but no power comes out of the box to supply power to the plugs......then just out of the blue, it does have spark.......Posessed????
Old Apr 26, 2005 | 01:08 PM
so you replaced the cdi box....did you replace the wires? what about the connectors that go into the box....
Old Apr 26, 2005 | 07:46 PM
fatduane1's Avatar
yes, I changed the CDI box & wires......connectors are all in good shape and well greased..... I'm thinking stator.....maybe?
Old Apr 26, 2005 | 09:46 PM
thats what was wrong with mine
Old Apr 27, 2005 | 05:07 PM
fatduane1's Avatar
Thanks, gonna save the $400 needed to buy from Polaris! Or I may search the internet and find someone who rebuilds them......Later
Old Apr 27, 2005 | 08:21 PM
SPORTSMAN70003's Avatar
Here is a guy on Ebay that rebuilds them.
