kawi lakota running like sh%#!!!
it runs for like thirty minutes then starts cutting out and bogging down....the it wont start till I let it sit for about ten minutes...then does it all over again...any help would be appreciated
check your plug, put in fresh gas, make sure your oil is not under/over filled, clean your carb, and check if the fuel switch thing is turned to on and not off or inbetween the 2. if its not any of this you could have a short or even a bad cdi box.
Frisky2050
Apr 9, 2020 11:19 AM
