110 octane
Old Apr 27, 2005 | 04:41 AM
2BIG2BFAST's Avatar
Default 110 octane
which brand of 110 octane do you guys use and which one do you think is the best?
Old Apr 27, 2005 | 07:49 AM
saint650's Avatar
Default 110 octane
ive always run sunoco. weither i needed 110, 100, or methonal. never let me down yet.
Old Apr 27, 2005 | 09:00 AM
devilontheDS's Avatar
Default 110 octane
the cycle shop i work at part time sells vp racing fuels so you can guess i run vp.
Old Apr 27, 2005 | 02:35 PM
Camds650's Avatar
Default 110 octane
I have always ran Sunoco Supreme in the race car and never had a problem.
"A true high performance leaded racing fuel designed for sophisticated high compression engines which routinely function between 7,000 – 10,000 rpm. Sunoco Supreme is trusted by some of the most respected names in motorsports. It is specially formulated with low sensitivity to achieve a high motor octane value for increased protection against detonation under severe operating conditions over higher sensitivity fuels of the same antiknock index. Sunoco Supreme is recommended for two- and four-stroke applications up to 15:1 compression ratio."
Old Apr 27, 2005 | 04:03 PM
reiner's Avatar
Default 110 octane
Sunoco 110, run it in my dirtbike too.
Old Apr 27, 2005 | 06:55 PM
Torquemonster's Avatar
Default 110 octane
I recently acqired a 55 gallon drum of Sunoco mx114. Does anybody know what the octane rating is on this. I thought it was 114 but the guy I got it from said it wasnt 114 octane.
Old Apr 27, 2005 | 07:39 PM
Sandaholic's Avatar
Default 110 octane
Torquemonster, in less time then it does to create your post a simple search on google got me all this info:
Sunoco MX - 114
Sunoco's high performance fuel for high-revving small engines, suited for the professional motorcycle racer.
Fuel Property Typical Specifications
Specific Gravity .74
Antiknock Index (R+M)/2 114
Reid Vapor Pressure 9
Lead 4.5
Oxygen, Wt. % 2.7
Distillation, ºF
Initial Boiling Point 90
10% Evaporation 138
50% Evaporation 220
90% Evaporation 255
Final Boiling Point 290
Oxygen 2.7% wt.
SUNOCO MX114 MSDS
Old Apr 27, 2005 | 09:08 PM
Budman650's Avatar
Default 110 octane
Sunoco+Nascar=Racing
Old Apr 28, 2005 | 09:02 PM
Default 110 octane
Sunoco MX - 114
Lead 4.5
Oxygen, Wt. % 2.7
Distillation, ºF
10% Evaporation 138
50% Evaporation 220
90% Evaporation 255
Oxygen 2.7% wt.
SUNOCO MX114 MSDS
In less time than it took you to read my post you could have ignored it. The smarta$$es are the reason I rarely post over here.
Old Apr 28, 2005 | 09:18 PM
Budman650's Avatar
Default 110 octane
I know it's easy to say "do a search" but then we wouldn't have a forum. I've asked old questions and everyone has been great. I'm still a newbie, too so don't let it get you down. I wish I could afford a drum of avgas or even 87 octane. Doesn't matter, 2big2bfast will still beat me.
