250 trail mod spring
Old May 2, 2005 | 12:28 PM
mudmaster250's Avatar
Default 250 trail mod spring
im gettin a 34mm carb soon and a race lightened flywheel and i want a set of S55s and either a red spring, red/yellow or maybe a blue. i like the high engagement so thats not a problem and i ride mostly all wide open so hard acceleration on take off is what i need. but are the S55s heavy enough to fully shift out the red or blue? thanks,
scott
Old May 2, 2005 | 06:48 PM
bump
Old May 6, 2005 | 06:34 PM
TwinAir2's Avatar
You know i have a RcR Pipe, and a clutch kit with a few other things done. My Clutch kit had the S58 weights, and the Red/Yellow spring. I thought it was pretty good, until i asked around and people told me that the S55 weights are ok, but if you go to a 52 gram weight, that is the best. So i found some weights that weighed 53 grams and put them in my trail blazer 250....from what i see by just trying it out around the house, it is way more snappier on the bottom end. The bike will wheelie alot better now. If you want some faster acceleration, then i would go with the 52 to 53 Gram weights.
Old May 6, 2005 | 06:36 PM
TwinAir2's Avatar
By the way, i forgot to say that i will probably be trying it this weekend, so i will let you know how it goes.
ghost civic
Jan 15, 2020 07:43 AM
mtdewmn
Jan 19, 2017 12:13 PM
chuck1177
Aug 11, 2015 03:22 PM
Wnthunting
Jul 9, 2015 03:02 PM
Mphillips
Jul 2, 2015 07:20 PM
