New Viper E-ton 70cc Won't Start
Old May 2, 2005 | 05:46 PM
1bad89gt's Avatar
Default New Viper E-ton 70cc Won't Start
Hey guys, I am having trouble getting this Viper 70 started. The quad has only been ridden about 3 times, but for some reason it won't turn over at all. It has power, the light on front and horn work with the key on, but it won't even kick the startor motor over. Before I start tearing this thing apart, does anyone have any suggestions?
Thanks,
Kevin
Old May 2, 2005 | 05:55 PM
Raptorlegs's Avatar
T Rex Rider
What irritates me is!
Those 6-packs work pretty good.
I'd start with the fuse, ground, tethers, ignition and kill switch.
Old May 2, 2005 | 07:30 PM
eton150's Avatar
not to be a smart azz but look at how much gas you have
Old May 2, 2005 | 08:29 PM
Bluetickracing's Avatar
Does the Eton have the safety switch on the brake Lever. Our AC brake lever had to be pulled in to start the quad. Michael clipped a tree and pulled the wires out and it wouldn't let the starter work. I unhooked it. Just a thought. Can you kick start it and does it have spark when you kick start it.
Old May 3, 2005 | 10:24 AM
1bad89gt's Avatar
Hey guys thanks for the help. The battery was low, yes you have to pull in the brake lever, kill switch was missing, and someone thought they would try and run it on some of the oldest gas I have ever seen!!! Anyways got everything drained and got it to turn over, took about 30 minutes of ride time to blow out all that nasty gas, but my little sister now has her LT80 for the dunes and her Eton for the track.
thanks,
Kevin
Rtgjje5
Jun 16, 2015 08:23 AM
Berjr
Jun 15, 2015 04:41 PM
Fnqrider
May 31, 2015 08:29 AM
1000gade
May 27, 2015 12:37 PM
jaybeecon55
Apr 4, 2000 01:50 PM
