85 250r axle
Old May 2, 2005 | 08:33 PM
dirtrider250r's Avatar
Default 85 250r axle
i was just wondering if a 86 250r axle would fit in a 85 250r
Old May 2, 2005 | 11:31 PM
dragracer789's Avatar
Yes it will
Old May 3, 2005 | 03:31 AM
AZ85Rs's Avatar
No, it won't. The bearings are different. One uses a standard type, while the other uses a taper style. Simply changing the bearings will not work. You must also change the bearing carrier.
The best thing to do is change the swingarm, axle, and bearing carrier to the 1986 and newer version. The aftermarket has many more parts for it. However, keep in mind that the rear caliper mounts are different. So, if you decide to do this, go all out and do it right.
Old May 3, 2005 | 03:59 PM
Wow guy, he said axle not bearings. The axle is the same, i guarentee it .
Old May 3, 2005 | 04:37 PM
AZ85Rs's Avatar
The bearings are precisely what make them different. One is a double-row style, while the other is a taper style.
If they are the same, why do the aftermarket companies offer one for the '85, and another for the '86? Look at these sites for reference:
http://www.nacsracing.com/htmlcatalo...iber-axles.htm
https://secure5.nexternal.com/shared...t=products.asp
Even BikeBandit.co lists different part #'s for the different years. (Although they have been discontinued). The '85 is 145642-001, while the'86 is 145643-001.
If you want to be absolutely certain, call the aftermarket companies and ask them.
Old May 3, 2005 | 07:05 PM
thanks for the info but i think dragracer is rite
Old May 3, 2005 | 09:07 PM
I dont really know what your trying to say but heres the deal. 85 style had a smaller carrier which needed a smaller outside diameter bearing race than the later models. The axles are the SAME. 85 will fit with 86-89's and vise versa.
Old May 4, 2005 | 03:33 AM
AZ85Rs's Avatar
Have at it. Let me know how it turns out.
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
1000gade
Sep 9, 2015 04:41 PM
