Polaris primary spring part numbers
Old May 5, 2005 | 11:09 AM
SPORTSMAN70003's Avatar
Default Polaris primary spring part numbers
Does anyone know where I can get the part numbers for a polaris white and a Polaris green primary springs?
Old May 5, 2005 | 11:39 AM
conig's Avatar
HPD uses the same part numbers as Polaris.
Polaris has them on there site as well, I can;t remeber the URL. But if you go online to there site, you can go to the accesary section and search for spring. It will pull up all the primary springs that Polaris makes.
hope this helps.
xcrider's Avatar
White should be 7041132, don't have the green
Old May 5, 2005 | 01:34 PM
Thanks for the info I found the numbers and the green one is 7041168.
Old May 5, 2005 | 02:00 PM
braveops's Avatar
look in my pics i have the part# in there
Old May 5, 2005 | 11:53 PM
NBsportsman's Avatar
SP70003 did you check out the Dalton blue?? It has a lower engagement than the polaris green or white and a higher shift out.....
Old May 6, 2005 | 08:45 AM
I might have to get one of those blue Daltons and try it.
WilliamBos
Sep 30, 2015 08:08 AM
wildbill59
Jun 20, 2015 02:26 PM
Big600twin
14
Jun 16, 2015 09:30 AM
FourWheelOverTwo
May 31, 2015 07:26 PM
