Recall???
Old May 5, 2005 | 06:16 PM
DsDemonKid's Avatar
Default Recall???
i've heard there has been a recall on the carrier of the ds650 from 03-05 leaving factory with little or no grease..causing back tires to lock up... any info?? my tires locked up yesterday
Old May 5, 2005 | 06:36 PM
2BIG2BFAST's Avatar
Default Recall???
I have 2 03s. A baja and the regular old red and black, I have not received any letters about the recall on them but i did receive one for my 05x. In the letter it only specified 04 and 05. Maybe i better check into the 03s. If you find anything out let us know.
Old May 5, 2005 | 07:16 PM
SCOUNDREL's Avatar
Default Recall???
Do a Goggle search for "Bombardier DS650 recall" and you will find way too much info. Or you can do a search here for bearing recall as well.
Old May 5, 2005 | 07:18 PM
SCOUNDREL's Avatar
Default Recall???
Model year 2004 and 2005 Bombardier DS650 ATVs under model numbers 0003A5A00, 0003A5B00, 0003B5A00, 0003B5B00, 000799700, 000799500, 000771900, and 000771700 are part of this recall. The ATV model number identification decal is located on the right side of the frame, in front of the engine.
Mine was an 04 and was not on the list. The bearings were dry and trashed.
Old May 5, 2005 | 07:20 PM
DsDemonKid's Avatar
Default Recall???
i'm using raptor bearings until mine come in
Old May 5, 2005 | 07:24 PM
SCOUNDREL's Avatar
Default Recall???
McMaster-Carr
REAR BEARINGS:
McMaster-Carr part number: 6677K23
Timken part number: 32008XM
Old May 5, 2005 | 07:31 PM
DsDemonKid's Avatar
Default Recall???
have you changed yours out as well??
Old May 5, 2005 | 07:35 PM
DsDemonKid's Avatar
Default Recall???
thanx for info...
Old May 5, 2005 | 07:37 PM
2BIG2BFAST's Avatar
Default Recall???
The only recall on the 03 i found was on the traxtor.
Old May 5, 2005 | 07:48 PM
DsDemonKid's Avatar
Default Recall???
yeh..i didn't find anything on 03 just 04-05 thanx
