250 trail boss runs and dies(HELP)
Old May 8, 2005 | 04:06 PM
hogkiller's Avatar
Default 250 trail boss runs and dies(HELP)
I have a 92 trail boss that will start and run for five to ten min. then if you try to give it throttle to keep it running then it sounds like it is sucking in to much air and will not run until it cools off again. It has 135 on the compression. any help would be greatly appreciated thank you.
Old May 8, 2005 | 05:01 PM
Budman650's Avatar
Is it running OK after it gets cool? I thought it might be seizing up, but the compression sounds good. You might have a lean condition causing it to run hot or just not getting enough fuel. Make sure you have gas running good out of the fuel line right at the carb. If not, check your filter. If gas does flow good, check your main jet, it might be partially plugged. Also check your float level and be sure gas is flowing past the needle and seat.
Old May 8, 2005 | 08:14 PM
hogkiller's Avatar
thats what it acts like is that its running out of fuel. New fuel line is on it. I will check the float level. and im running it 32:1 the oil pump was removed and plugged off. thanks
Old May 10, 2005 | 05:23 PM
hogkiller's Avatar
still need help thanks.
Old May 10, 2005 | 05:44 PM
Budman650's Avatar
What happens when you you use the choke after it dies? Does the engine rpm increase? If so, it's probably still starving for fuel. Even though the compression sounds good, check for a bad head gasket. See if there is an oily residue where the head and cylinder come together. Is the spark plug wet when it dies? You might have a ring sticking when it gets hot and you loose compression. You might have to do more checking right after it dies. Did you take the main jet out and actually see daylight thru it? Do you have spark when it dies? Maybe something electrical is breaking down.
Old May 10, 2005 | 06:21 PM
hogkiller's Avatar
thank you i will check on these items and list the results i do appreciate your time and help.
Old May 10, 2005 | 09:09 PM
95sport400's Avatar
Run it until it starts to die and immediately unscrew the gas cap. If it keeps running, your vent line is kinked. Happened to my '93.
Old May 10, 2005 | 11:18 PM
Budman650's Avatar
I knew someone would come and help. There is always someone who has had a similar problem. I'm just guessing at this point without being there when it happens.
"95", your woman quote is excellant. They just had a thread on favorite quotes in the "bomb" forum. That should get a thumbs up from us old married guys.
Old May 11, 2005 | 08:10 PM
hogkiller's Avatar
thanks i belive the vent tube might have been the issue along with putting the air filter back on it. it does not want to die and does not sound like a vacum cleaner any more. I have one more question about the top motor mount it has rubber busshing between it but the motor can move alot. the bushing are touching but not connected to each other. i looked at a few parts finders but i can not tell what parts are what or if this is okay. thank you for your help,
Old May 11, 2005 | 08:36 PM
tmzg29's Avatar
hogkiller,
I have a 1999 polaris scrambler 400 and when you watch the motor sit at an idle it looks like the motor is going to jump out of the bike. I also have a 02 trailblazer 250 and it does the same. If the bushings are still there and you are worried about the motor jumping around, I think this is normal for these bikes.
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
wildbill59
Jun 20, 2015 02:26 PM
PolarisPower500
May 17, 2015 02:28 PM
EXtreme
Sep 10, 1999 12:54 PM
Matt24
Aug 3, 1999 07:46 PM
