Adjusting predator valves......
Old May 9, 2005 | 01:16 PM
Rider1169's Avatar
Default Adjusting predator valves......
About time for an adjustment id say, where to begin? My friend has no idea, either do I for the pred. What specs should they be at and can you guys give me a walkthrough on the process?
Thanks-----Rider1169
Old May 9, 2005 | 01:32 PM
04predator2's Avatar
ok frist take valve cover off find tds the intake .0006 exhaust is .10 and between +/- .0019 if you need more info just reply I can walk you through it good luck!
Old May 10, 2005 | 03:28 PM
Morewood's Avatar
When do valves need adjustment, and how often?
Most 4-strokes its mainly the intake valves that need adjustment, same on a Pred??
Do you have to take anything else off to get the valve cover off or to get wrenches to the adjusters??
Old May 10, 2005 | 03:33 PM
no adjusters the predator uses valve shims under a valve bucket you use a feller gauge and add or loos shems to get the right clearences. just th valve cove is all you need good luck!
Old May 11, 2005 | 09:35 AM
Rider1169's Avatar
Oh, so theres no adjustment? Its just adding or getting rid of shims?
Old May 11, 2005 | 10:17 PM
omahapredator's Avatar
you change the thickness of the shims
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Whitelx1
Oct 2, 2015 10:55 PM
wrencher82
Sep 30, 2015 04:27 AM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
