Pulling off drive pulley
Old May 11, 2005 | 11:17 PM
300win's Avatar
Default Pulling off drive pulley
I am in the process of fixing my starter on a 1995 Polaris Explorer 400, I removed the pull start and the 2 screws from the starter,moved to the other side ,removed the drive belt and secondary clutch,now, my manual says I need a special puller #2870506 to get the drive pully off, can I not use a ordinary puller? Whats so special about this puller?Can I unthread the bolt half way and use the puller against the head of the bolt and pop it off? TIA.
Old May 12, 2005 | 11:01 AM
xcrider's Avatar
The problem with a jaw type puller is that a lot of pulling force is out from the shaft and can crack the clutch. The clutch pullers use a larger threaded bolt that tapers down to push against the crankshaft it. The larger thread engages the clutch itself where is it beefed up so no damage will be done. Click on this link to see photos of another guys website that shows alot of clutch tools, some home made others bought.
Old May 12, 2005 | 12:08 PM
CED's Avatar
CED
If you can find a 3/4 " fine thread rod you can amke your own puller.You are actually pushing against the crank to get it off.
Old May 12, 2005 | 01:02 PM
300win's Avatar
Wow, thanks for the great replies! Very helpfull. I think I will try to find a 3/4" fine thread bolt and make my own,just phone the polaris shop and they want $56.00 plus tax! Cnd.Again,thanks for the help!
Old May 12, 2005 | 03:40 PM
CED's Avatar
CED
Just make sure that the shaft is long enough,so it wont bottom out against the clutch.Jam you 2 nuts on the end and there you have it.
Old May 12, 2005 | 10:19 PM
300win's Avatar
Worked like a darn! Went and bought a 3/4x6 fine thread bolt,and found some bronze stock I had kick'n around,cut it to 4" slid it in ,tightened the bolt up and one smack with the hammer and off she popped!
now just got to figure out whether to rebuild the starter or buy a new one??? I see on Ebay there is lots of stuff out there,any other good places to purchase parts (other than the dealer)?
Old May 13, 2005 | 12:08 AM
kentuck's Avatar
buy new you will never regret it.
SDR-II
Sep 29, 2015 01:06 AM
metal249
Jul 24, 2015 01:00 PM
Desimation2k8
Jul 17, 2015 12:37 AM
clsharky
Jul 13, 2015 02:07 PM
tporath
Jul 11, 2015 12:31 PM
