Creeping
Old May 17, 2005 | 12:49 AM
Traildog's Avatar
Default Creeping
How many of you have or had a creeping problem and had to replace your primary clutch to fix it?
Old May 17, 2005 | 03:09 AM
polarisbear500's Avatar
Default Creeping
ME!!!!i just did this one month ago, mine was terrible.
it started off only doing it after i had road for a while, but then it started to creep as soon as i started so i replaced the primary and all is well
Old May 17, 2005 | 05:06 AM
jimmypsp700's Avatar
Default Creeping
Turn the idle down.
It will creep and be hard to shift if the idle is turned up too high.
JIm
Old May 17, 2005 | 08:55 AM
PolarisUK's Avatar
Default Creeping
Wow, replacing the primary clutch seems extreme for a bit of creeping!
As stated above, wouldn't turning the idle down sort it out?
Failing that a rebuild of the clutch?
Old May 17, 2005 | 09:35 AM
GLAZIN1's Avatar
Default Creeping
A WORN BELT WILL ALSO CAUSE CREEPING.
Old May 17, 2005 | 10:50 AM
Speedwerx's Avatar
Default Creeping
Have you guys check your belt deflection and or clutch alignment, you idle hsould be at about 1200 rpms.
Old May 17, 2005 | 08:33 PM
Default Creeping
i had my idle checked on a machine by my mechanic and it was too high at one time, but they adjusted it and it still creeped, and it slowly got worse and worse. i have my old primary and it is awful, i needed a new one badly.
Old May 17, 2005 | 09:48 PM
BigDog800EFI's Avatar
Default Creeping
Dealer just replaced a buddies 800 clutch. They tried everything and it would not stop creeping. Replaced the clutch and all is back to new.
Old May 18, 2005 | 01:34 AM
Traildog's Avatar
Default Creeping
<FONT size=2>
In most cases adjusting the idle does not fix the problem and the fix unfortunately is to replace the primary clutch. It comes down to a worn clutch assembly.
Until now nobody rebuilds these clutches so the only option is to buy a new assembly. I say until now because we are in the process of testing our rebuilt clutch, which we finished just a week ago. If the testing goes well and the clutch stands up to trail use we would consider producing rebuilds for sale. Is there a market for rebuilt clutches?</FONT>
Old May 18, 2005 | 01:54 AM
Default Creeping
depending the amount you are going to charge, then yes there is a market. for me being someone having to replace my primary, i would have much rather had it rebuilt as long as there was a warranty/guarantee with it. this is all my opinon though. pb500
