where do you get your K&N oil?
Old May 18, 2005 | 04:14 AM
jimmypsp700's Avatar
Default where do you get your K&N oil?
Where is the best (read cheapest) place to get the K&N cleaning kit?
Actually I only need the K&N oil for now if they sell it that way.
Also do you use an alternative oil (although I wouldn't recommend it)?
I usually just get it at the auto stores.
thanks,
Jim
Old May 18, 2005 | 06:56 AM
DubaiPolaris's Avatar
916 Reaper - Pure Evil Inside!
I get my K&N filter oil from the local bike shops here (I know that don't help you much in that dept.). I have used the KLOTZ filter oil for K&N guaze type filters, with no problems. The only thing I did not like about using the KLOTZ filter oil is that it is almost clear, which makes it a harder to see if you miss a spot, compared to the red K&N oil.
Thanks Chris
Old May 18, 2005 | 08:29 AM
so far this is what i have found...
http://www.magicracing.com/product.a...=488&catid=144 kit 8 oz. $11
http://www.magicracing.com/product.a...=486&catid=144 oil 12 oz. $9
http://www.rockymountainatv.com/Product_Show.atv?cat=OIL&type=AIR&name=K+and+N+Fil ter+Oil K&N oil 12oz. $7 / 6.5oz. $6
http://www.rockymountainatv.com/Prod...v?pid=00003195 K&N kit $10
Old May 18, 2005 | 01:33 PM
95sport400's Avatar
Amsoil makes a filter oil available in bottle or spray can. It's also cheaper than K&N's.
Old May 18, 2005 | 03:16 PM
RAJ's Avatar
RAJ
You can also buy it from NAPA auto.
Old May 18, 2005 | 07:10 PM
speeeedy's Avatar
i have a k&n but i use notoil oil.
Old May 19, 2005 | 03:49 AM
Thanks for the help guys.
I got the Bel-Ray brand Fiber filter oil for $6 (16oz.) at Magic Racing instead of the K&N oil for $8 (12oz.).
I have the Bel-Ray chain lube and its quality stuff, the guy working there said its the same and just as good as the K&N oil.
They had like three different brands and sizes available as well as the cleaners in bulk.
All the auto stores only sell the K&N recharger kits and that only includes a 6.5 oz. oil. Kits range from $10-13.
Thanks,
Jim
Old May 19, 2005 | 04:48 PM
BubaHyde's Avatar
JUST AN ADDED NOTE: <SPAN class=postbody>Formula 409 is basically the same as the K&N cleaner</SPAN>
