blaster cylinder question
Old May 25, 2005 | 02:47 PM
2strokesceamer's Avatar
Default blaster cylinder question
Does anybody have the ultimate 30hp trenga cylinder? If so what do you think about it and does it really wake it up.
Old May 25, 2005 | 02:58 PM
lethaface's Avatar
I have never heard anything about the cylinder's performance..I don't think you will be able to get 30hp out of it without a carb and pipe..The only thing i have really ever heard about trenga is that they have bad customer service..I would check around before you commit..There is so many other builder's out there that have better prices then trenga..
Old May 25, 2005 | 03:08 PM
How do you like your hwd pd 2 porting, prophead mod, and flywheel. do you know what hp you are pushing.
Old May 25, 2005 | 03:56 PM
lethaface's Avatar
low 30's
Old May 25, 2005 | 04:38 PM
Can you still wheelie with that swingarm and do the wheel spacers hold up ok on jumps
Old May 25, 2005 | 05:26 PM
lethaface's Avatar
Yeah you can still wheelie with the swingarm..The spacers is the cheap way of doing it..I just ride trail's so the longer A-arm's/extended axle really wasn't a must have..They have held up pretty good so far and i do ride the bike pretty hard..I guess it just depend's on what your riding style is..
Old May 25, 2005 | 05:40 PM
Can you use a banshee axle. I think it would be like plus 2
Old May 25, 2005 | 05:43 PM
also does hwd revalve and shorten 250r shocks to fit blasters
Old May 25, 2005 | 05:45 PM
lethaface's Avatar
Yes you can but you will need the banshee's hub's..A good way to get 3-4 inches wider is to use a banshee rear axle with raptor rear wheels..You dont' really have to use only banshee hub's..You can use banshee, yfz, raptor, or warrior. .For the rear i got 5 inch spacers with raptor rear wheel's to give me somewhere around 48 inches wide
Yes they do shock work as well..
Old May 25, 2005 | 05:51 PM
ok thanks
