chain adjustment problem
Old May 25, 2005 | 08:54 PM
DS650power14's Avatar
Default chain adjustment problem
hi,
i have a problem with my adjustment. when i go for a ride, i adjust my chain and tighten the bolt as hard as i can but it loosen itself by the end of the ride... did anybody had this problem and how did you resolved it?
also, the bracket that holds the rear galiper is loose on the bearing carrier. i am going to change it but did anybody also had this problem? i can't find out how it could get loose... it seems like the bracket is bigger than the bearing carrier..
Old May 25, 2005 | 09:00 PM
blue250r's Avatar
If every thing keeps coming loose on the rear i would check the rear bearings are running smooth, it could be caused by vibration
Old May 25, 2005 | 09:07 PM
chiknhawk's Avatar
mine started doing this just before my rear locked up while doing 75-80 mph!!!! my bearings seized to the axel and in the carrier. i had to cut the carrier off the axel total cost of 225.00 bux. better check into it before it is too late. Chicknhawk
toonces
Oct 16, 2019 12:11 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
Sjrpp
Jul 5, 2015 09:04 PM
ranvette
Jul 4, 2015 06:13 PM
