grizzly hates water
Old May 26, 2005 | 05:58 PM
droil5's Avatar
Default grizzly hates water
has anyone found issues with crossing water and engine sputters is it moisture in belt snorkle or is it steam getting in the air box seem quite common with yamaha
Old May 26, 2005 | 07:10 PM
Dirtydude's Avatar
they are a bit too rich from the factory so when steam enters the airbox it reduces the air/gas mixture even more and causes sputtering, so i've deduced from other posts and such
I plan on getting a jet kit, I hear it solves the problem
mine does it too, sucks when you need the power and it just sputters and snaps
Old May 27, 2005 | 07:53 PM
buckshot12's Avatar
i guess that i'm pretty fortunate, i've never had that problem with mine and i 've gone through some ppretty deep water crossings. just for kicks.....do you guys switch to diff lock just before the water. because if you do, check to make sure that it's fully engaged before you attempt to go. (the light should be solid, not blinking) otherwise it will spit and spudder until it engages. forgive me if i insulted your intelligents[img]i/expressions/face-icon-small-smile.gif[/img]
Old May 28, 2005 | 09:47 AM
zappa24's Avatar
Take a small amount of petrolum jelly and put it in the end of the spark plug cap. It should seal the plug so water won't get up in there. Don't know if this will help but it's worth a try. Yamaha also has a grease for this purpose.
Old May 29, 2005 | 02:15 PM
grizz32's Avatar
I guss i'm lucky to had my grizz in water up to the seat and never had any problems[img]i/expressions/face-icon-small-smile.gif[/img]
Customer Service #1
May 15, 2020 08:46 AM
shimanok2
Jan 29, 2016 07:37 PM
cboler9
Sep 24, 2015 08:35 PM
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
