Differences Between 2004 and 2005 SP 400?
Old May 29, 2005 | 01:57 PM
oldsmoboat's Avatar
Default Differences Between 2004 and 2005 SP 400?
When looking for after market parts, I rarely see anything listed for the 2005s. Will 2004 parts work or was their a motor as well as body change?
Looking for a pipe with more low end and maybe a clutch for more low end.
Old May 29, 2005 | 03:07 PM
number4's Avatar
I believe the same 425cc motor was used.That being said i think performance mods would be the same for an 04 to 05.
Also,as i once had a 400sp,I would say you'll be amazed at what a clutch kit will do to these machines!
Old May 29, 2005 | 03:13 PM
oldsmoboat's Avatar
Which kit did you use?
EDIT
A mechanic told me he could turn my clutch 1/4 turn and get more torque, anyone heard of or tried this?
Old May 30, 2005 | 12:30 PM
Kushman's Avatar
Mechanicly, the 04.5 and the 05 are the same....correct me if I'm wrong....only changes being the plastic , racks, lights, ect.....
keep in mind the 04 and 04.5 are different in the central hillard vs. outside hillard, and the tranny
Old May 31, 2005 | 01:05 AM
tyler711's Avatar
04.5 and 05 are not completely mechanically identical, the 05 has both inner and outer cv joints, and I am sure the wider stance required some changes in the driveline. Also longer suspension travel. Only slight differences, probably not anything that would decide if an aftermarket part would fit.
Steeldon
Sep 9, 2015 09:38 AM
Brandon400
Sep 7, 2015 12:20 PM
Brandon400
Sep 5, 2015 08:44 PM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
quickwhips
Sep 2, 2015 06:53 AM
