stock exhaust question
Old May 30, 2005 | 09:55 PM
S10ripper's Avatar
Default stock exhaust question
i have a 2001 honda 250ex would it be bad if i ran it without the spark arrestor on? i have heard sooo many conflicting stories i don't know what to believe. thanx
Old May 31, 2005 | 08:43 PM
Wheelerbob's Avatar
Probably since honda's are notoriously lean from the factory, (emission's requirement's). Any change's you make you should rejet, if you don't you run the risk of running lean and overheating. This may or maynot cause severe engine damage, for the price of a couple keihin jet's from your local dealer IT"S NOT WORTH IT. Stock is 95 if you take the baffle out you should probably go up to a 98 maybe even 100 due to the lean jetting from the factory.Hope this help's.
Old Jun 1, 2005 | 04:21 AM
White7's Avatar
thats correctomuno,,You definatly will want to bump up your main jet,,youll be suprised at the increase on the bottom end power just from pulling the S/A and re jetting
Cole Hadden
Jun 15, 2025 09:05 AM
slowgsxr97
Mar 18, 2022 03:40 AM
cSchwartz
Jul 12, 2015 07:42 PM
1966F100
Jul 12, 2015 03:08 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
