Need Some Advice
Old May 30, 2005 | 10:06 PM
cbfreeman709's Avatar
Default Need Some Advice
Hey i got a scrammy 500 in december 04 and i am very unhappy with it. It is a big 500 and it wont pull hardly anything itll jus start smoking and burn up the clutch. I was at the lake last weekend and was in the sand and i got stuck and put it in 4wd and the wheels wouldnt move and the burned up im so pissed. So i want to trade it in for a preddy 500 TL edition is this smart. i mean other than the clutch smoking this fourwheeler has been flawless so i should be able to get a good trade right????
Old May 30, 2005 | 10:15 PM
jayri's Avatar
I rode one with a hot seat clutch kit and I tried to smoke the belt and couldn't do it! Maybe you need a clutch kit??
Old May 30, 2005 | 11:12 PM
ftwflh's Avatar
I suggest that you learn how to ride a CVT .I have rode them for years and have yet to "smoke "a belt.
Old May 30, 2005 | 11:19 PM
Listen here i know how to ride a CVT this is my 4th one and the only one i have smoked!!!! This is jus a little more sensetive and if u rode mine it is so sensetive so all i asked was for advice, get off the fourhweelers and get into the rocker old man.
Old May 30, 2005 | 11:22 PM
ftwflh's Avatar
Ok now that I got your attintion !!!! Check the secondary clutch for binding and be sure your air ducts are clear.
Old May 30, 2005 | 11:42 PM
Bubba297's Avatar
Yeah "old man" get into the rocker[img]i/expressions/face-icon-small-happy.gif[/img] LMAO
A little more sensitive??????? Give me a break. If you know how to ride the machine and you use the high/low range correctly then you have either a venting problem or the clutches have issues, ie alighment, deflection, broken parts, etc.
Old May 31, 2005 | 07:34 PM
ftwflh's Avatar
Sorry to tell you that I dont have a "rocker" I have a lift chair[img]i/expressions/face-icon-small-tongue.gif[/img]
Old May 31, 2005 | 07:50 PM
XtremeSkier's Avatar
Why did u buy it if u had plans to pull stuff with it? it doesnt have a low range, our dealer told us not to pull anything with it because there not built for it, ive had the belt somking on mine but thats cuz it was 90 degree's out and i had it pinned in the mudd, I recommend a clutch kit and exhaust, really help it get offf the line and have more spunk, like every1 else said
Old May 31, 2005 | 09:52 PM
BryceGTX's Avatar
Hey cbfreeman709. Its doubtful that you got the rear wheels so jammed it couldn't get it out. You probably got sand or mud jammed in the chain.. stops it dead. If you don't clean it out, you will burn the belt. It happens most often when you high center the rear axle in thick really gooey mud. The mud gets jam packed into the front and rear sprockets and chain. You have to be careful with any chain driven quad because in this type of situation.
BryceGTX
ultangler
Nov 30, 2024 01:35 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
kodiacrunner
Oct 4, 2015 11:52 AM
wrencher82
Sep 28, 2015 10:02 PM
