air fuel mixture screws on BF750
Where are these screws am I blind and just cannot see them on the carbs??? The prairies are really easy to find and adjust. I cannot see them on the brute??? What gives. I have a backfire issue from WOT to idle and it has a stumble on the low end. It is not the low speed miss that was taken care of. The plugs are black so it is running rich. Also does anyone know if the 6e plugs are hotter than the 7e plugs??? Thanks.
If you dont know where they are at, you probablly wont find them. Almost impossible to adjust without removing everthing. Screw the new needle!!!! You will probably gain other problems when you loose the low end miss. Get the Dyno Jet, unbelieveable throttle response with this. It solves all stock Brute carb problems and is well worth the money. Or you can keep dicking around with your dealer and loose out on riding time. They want you to keep having problems, they get paied by Kawasaki for your fixes.
