BRAKES STOP!
Old Jun 1, 2005 | 11:24 PM
trailblazermudrunner's Avatar
Default BRAKES STOP!
I CANT FIND THE AFTER MARKET BRAKSES FOR A 2000 TRAILBLAZER 250 AND I WAS WOURNDING IF THE NEW TB'S BRAKE PADS WILL FIT?
HELP
Old Jun 2, 2005 | 12:37 AM
ScramaDamaDingDong's Avatar
you use the same brake pads as the ones on my 2000 scrambler. I just bought a set off of ebay. just do a search for scrambler brakes. these pads are very common to polaris models. The fronts are the same as the predator. the rears have one tab in the center and one hole in the center for the pin. Click here for a link to some pads that will work that's a good example of what will work for you. you may be able to find them cheaper if you look around ebay a bit. the rear pads for the earlier scramblers won't work. they have two pin holes on top. hope this helps you out a little
Old Jun 2, 2005 | 12:38 AM
I think your shift key is sticking too, might have that looked into.
Old Jun 2, 2005 | 09:29 AM
so if i go on rockymoutain.com and do a search for say 2000 polaris scammy and find brake pads the pads from a scammy will work on the 250 trailblazer
Old Jun 2, 2005 | 09:31 AM
then that might mean the newer modle trailblazer pads will work then
Old Jun 2, 2005 | 09:33 PM
help
greg74
Sep 10, 2019 03:03 PM
Shainasmash
May 8, 2017 06:38 PM
Stirling
Aug 9, 2015 01:49 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
