whats hpd use in the race mod clutch set up
Old Jun 5, 2005 | 01:26 AM
mudmaster250's Avatar
Default whats hpd use in the race mod clutch set up
i need something that egages fairly high. my power kicks in about 3700-3800 rpm. im thinking either S53s with a red spring or s55s with a red/yellow. but i was also wondering what hpd sends in there race clutch set up. im also gettin a 34mm carb and trail lightened flywheel when i get this stuff. my clutch set up now is custom grinded S55s with a hpd brown. its set up to where it egages good but still has a little hesitation. the full shift it is really slow. i can beat a warrior by about a bike length or two through his first 4 gears and then he walks away. the top speed on mine is 58 and his is 60(GPS) so i know its not that. it just takes forever to fully shift out. any help is apriciated. thanks,
scott
Old Jun 5, 2005 | 10:47 AM
theCATman's Avatar
Either the HPD Blue or Violet would give you the high stall you're after. My one riding buddy & I put in the HPD Blue in place of the red/yellow that came with the HPD aggressive kit. DON'T use the red/yellow if you want high stall. Yea, for the average person it does fine, but for all out performance it doesn't engage high enough & the engine bogs at take off. Either the blue or violet will get the engine "on the pipe" right away for instant power & response.
Old Jun 5, 2005 | 05:24 PM
what weights do u use with the blue spring? im gonna call rick and have him send me a set of S55s with a red spring (136/242) and a set of S58s with a blue spring(147/285). i think the red with S55s or maybe S53s might be a better set up since it wont engage quite so high since itll just dig a hole in mud. thanks
scott
Old Jun 5, 2005 | 08:52 PM
tbsleeper's Avatar
i gotta get a top speed on mine...i was scares sh!tless today drivin it on my trails and thats a first for me...o ya im still jetting it
but just run wat i run in mine we got basically teh same setup
Old Jun 6, 2005 | 05:30 PM
i talked to dennis and he said with my porting to run a red spring with S58s and for the jetting to run around a 200 main. use the 250 needle and needle jet and teh 400 pilot.
Old Jun 6, 2005 | 07:50 PM
tbsleeper's Avatar
ya he told me the same...im runnin a 190 main jet and its rich right now
Old Jun 7, 2005 | 12:34 PM
im runnin a 190 with my stock carb right now but once it warms up past 75 im goin back down to a 180. i hope the clutching works. im tired of that bog.
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
awer1968
Sep 8, 2015 11:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Logan Collins
Sep 5, 2015 08:03 PM
Sep 1, 2015 01:45 AM
