Need help with ATC 125
Old Jun 5, 2005 | 05:41 PM
MrG's Avatar
MrG
Default Need help with ATC 125
I have an ATC 125 honda and i want to get it running good again. Its the modle with with the high and low range
The bike use to run good and strong, but now when i give it gas it usually bogs and dies and flooeds with gas. When the bike is off it leaks gas with the gas key turned off.
The spark plugs also need attention alot.
Anyo ne have any suggestions? or a good website for parts? thanks.
Old Jun 6, 2005 | 02:04 PM
ThrashAndCrash's Avatar
Rebuilt the the carb and change out the plug. You will need to find out what year it is, but Hyperparts carries the carb kit and plug if you need them. Most motorcycle shops should be able to order the stuff you need.
Old Jun 6, 2005 | 03:27 PM
DirtRyder420's Avatar
sounds like the carb float to me, could have a hole in it or the pin could of slid out of place this is fairly comon on those ...pull the carb off then take the bowl off and inspect it youll see if the pin came out if thats not it then take the pin out and pull out the float and shake it to see if it has fluid in it ..they usely develop tiny holes around where the float is seamed together ..this can happen if it has been sittin for awhile ....the carb could also just be toast...?
