any tips?
Old Jun 5, 2005 | 09:26 PM
hondaman300ex's Avatar
Default any tips?
does anyone have any tips on freeing up a froze axle nut on 300ex?
Old Jun 5, 2005 | 10:12 PM
TractorPacker's Avatar
Do you have a balloon?
Default any tips?
If its the skinny lock nut, you can split it with a chisel. You would need a new one after that but it would be off. You can also use that same chisel and hit on the point of the nut and usually get it to spin. A 2 pound hammer hitting a chisel can put alot of force on the nut.
Old Jun 5, 2005 | 10:22 PM
Code54's Avatar
Default any tips?
Also may want to try heat - not a cutting torch but a propane and keep focused on the nut (watch for anything else that can burn -brake lines, plastic, etc...) Heat and the info in the last post together should work.
Good luck
exmotocrosser
Sep 26, 2015 08:18 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
cornermike
Sep 10, 2015 08:30 AM
Stever6368
Aug 16, 2015 07:34 PM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
