Is the Aaen clutch kit good?
Is the Aaen Power Shift kit and a full Hpd Exhaust a good combo. Im looking for a clutch kit that will give the most torque?
Any suggestions Oh it will be on a 500 Scrambler
From what i have been told its not good to mix match manufacture'r brands when u use a pipe and clutch kit. For example if u get a HPD exhaust, get the HPD clutch kit, Aaen clutch kit/Aaen exhaust.
On a 4stroke the clutching isnt as important as on a 2stroke in matching to the pipe.You need to clutch your 4stroke to suit your style of ridding.Personally if your 500 isnt piped or anything I would run the Aaen blue secondary with either a polaris green or Dalton blk/white primary.
I personally dont like the aggressive kit it engages too high and you loose some of your low end torque.I run a polaris yellow spring with a set of 10MB (50.5 grm) weights with a TEAM roller and my top rpms aree 5700-5750.And still have tons of lowend.
hoopduerr
Jun 2, 2015 09:01 AM
hoopduerr
Jun 1, 2015 08:22 PM
