39mm FCR's with Yoshi pipe
Old Jun 11, 2005 | 07:44 AM
raptorgav's Avatar
Default 39mm FCR's with Yoshi pipe
Just ordered my new 39mm fcr setup off craycraft for my 730 rebuild and are not sure if the carby's will clear the front pipes of the yoshi. Has anyone run this setup? ( i know this is not the best exhast for a bigbore). BTW i have the offset inlet manifold from bob, very impressed, will this help !!
Old Jun 11, 2005 | 08:03 AM
vinny3299's Avatar
yoshi is one fo the top models on exhaust... why ou think so many street bikes have themm too
Old Jun 11, 2005 | 08:09 AM
raptorgav's Avatar
From what I read the yoshi is yery good on stock motor's but for the 730 it is restrictive, especialy the head pipe. I have not had this new build running yet so I am no expert.
Old Jun 11, 2005 | 08:21 AM
vinny3299's Avatar
i dont see what else would be better may haveta find a pipe speicific for the size motor your going to be running check with yosh. they may have a answer for ya
Old Jun 11, 2005 | 09:36 AM
maddog56's Avatar
Vinny, the yoshi is a great pipe for a stock bike but I wouldnt have one on anything with a ported head. Yoshi is not the best for the raptor at any stage of tune but it is a good pipe for stock to mild bikes.
I've heard of a few guys running 35mm FCR's with the yoshi pipe, some have no problem others have put washers in the mounting location for a little extra room. I believe they do work but I havent seen it first hand and it will depend on the intake and filter setup you use.
Old Jun 11, 2005 | 11:03 AM
King660r's Avatar
Get rid of that yoshi for some Barkers or LTEs. I had the sparks on my 730, which flows more than the yoshi, and it was restricting my motor bigtime. I switched to the Barkers and it was really a huge difference. Sell that yoshi if you want top performance out of your built motor.
Old Jun 11, 2005 | 02:56 PM
homdaddy's Avatar
i was wondering the same thing but i have big gun setup .how do the barkers do on the lower end my 740 rocks down low and i know the current exhaust is holding it back. but i dont want a set up that has a huge hole in it and makes a light switch out of it.
Old Jun 12, 2005 | 02:09 AM
King660r's Avatar
I had the regular sparks X-6, not the race core sparks. The Barkers are definitely a more top end exhaust, but with the torque of the 730 down low, combined with Bobs custom cam, and the Barkers throwing out the exhaust, it really made a huge difference. The sparks just wasnt allowing my engine to breathe, which holds back a lot of potential. I felt a very noticeable gain over the sparks without suffering tremendously down low. I felt it was money very well spent.
On the other hand, I only got about 2 hours of riding with my new barkers before one of my exhaust valves broke and locked my entire engine up, plus took out an intake valve. But those 2 hours were a lot of fun [img]i/expressions/face-icon-small-wink.gif[/img]
Old Jun 12, 2005 | 03:16 AM
maddog56's Avatar
The barkers are LOUD. And the quiet cores really plug them up too. If I were to spend a lot of time at sound restricted areas I would go with the LTE duals.
Old Jun 12, 2005 | 02:07 PM
homdaddy's Avatar
moddog
nice bike! how loud is loud are you saying they are louder than a sparks or yosh? and what is that blue thing in your cylinder?
