oneway question
Old Jun 12, 2005 | 11:55 PM
homdaddy's Avatar
Default oneway question
how do you know when your one way is bad?. i just put my engine back together after the trans upgrade. when it is in neutral and the light is on you hit the starter button and it turns like a dead battery.but it is new and it did this before i tore it down just not as bad but the motor is tight. you can spin the oneway clock wise fine and it seems to lock when you turn it counterclockwise. if you tap the button it will turn it over . if you hold the button on it will some times turn it over not very fast and the positive wire and solenoid gets hot. any help or hints would be great .
thanks kevin
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
