Hot cam or web cam for 04 Raptor ?
Old Jun 15, 2005 | 06:42 PM
raptornuts's Avatar
Default Hot cam or web cam for 04 Raptor ?
I em ready to add little power to my raptor. Thinking about camshaft, I em incline to purchase the stage 1 hot cam, but maybe web cams are better. What is your take on this ? Did anyone try both of them ? THX
rnuts
Old Jun 15, 2005 | 11:28 PM
BigScary's Avatar
if everything else internally is stock i'd run the stage 2 hot cam........bypas the stage one......they suck......trust me....I wasted my money on one........
Old Jun 16, 2005 | 02:07 AM
scottd's Avatar
How do they suck? The specs indicate more lift & duration than a stock cam. The problem with the stage 2 cam (for those who want to make the swap as simple as possible) is that they require changing the valve springs & retainers. Just wanted to know WHY you think the stage one "sucks". Give us some reasons, as I'm thinking of putting in one of those myself.
Old Jun 16, 2005 | 08:14 AM
UBETRUN's Avatar
Stage 1 is not much of an improvement over stock, Stage 2 is more noticeable.
Old Jun 16, 2005 | 09:50 AM
sixsixT's Avatar
I just took out my stage 1 and put the stock cam back in.[img]i/expressions/face-icon-small-tongue.gif[/img] I guess with the mods I have the stock cam just worked better for some reason.
Old Jun 16, 2005 | 11:12 AM
garyc660R's Avatar
IMO, the stage 1 hot cam makes a nice improvement in low end and mid range and the stage 2 hot cam takes a little from low end and ads top end. I wasted money on the stage 1 initially as well....I like the stage 2 better. The core charge with the web cams no doubt hurt sales. With that edelbrock carb I would not go over a stage 1 or equivelent cam though....it's not gonna move enough air for a big top end gain anyway. My $.02.
Old Jun 16, 2005 | 12:43 PM
raptornuts's Avatar
Just curious, what mods you do have, that work better with stock cam ?
rnuts
Old Jun 16, 2005 | 01:09 PM
sixsixT's Avatar
Dual K&N air filters w/ my bracket, modded stock carbs w/ GYT-R jet kit, matched the intake to the head and a Yoshi pipe.
With the stage 1 I could not get rid of a low end bog, it wasn't bad but annoying. With the stock cam at the dunes with paddles (no traction problems) on level ground I could cruise 3rd gear in the lower to mid RPM range and pull the front end up at will with only the throttle, no clutching, leaning back or tugging on the bars just give it gas. I couldn't do that after putting in the stage 1 cam and I didn't feel I gained any top end either in fact I may have lost a little. I also spent quite a bit of time jetting each set up.
That's what my experience was but like I said it doesn't seem to be the norm.
Old Jun 16, 2005 | 01:28 PM
sixsixT's Avatar
I didn't notice that you have the Edelbrock till Gary mentioned it.
I think you'll see a lot more gains from cleaning the intake manifold up then you would from a cam. That intake is the the worst I've seen and has lots of room for improvement. Check out my photo page. They were supose to come out with an improved filter adapter too but I don't know if they did or if you got it, but that wasn't designed to well either. IMO
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
