what size bearing for crank on 325 magnum
i have a 2000 model 325 magnum 4*4 and have recently had to put new conn. rod assembly, cylinder, piston etc.
on the 2000 model any units made after march 1 use oversized bearings on the crank ( .05 or .025 U/S ).
does anyone know which one to use ( the dealership gave me the wrong one ((the standard size for earlier model quads))) and it turned on the crank . i need to get the conn. rod turned down ( not a lot of marks on conn rod but some).
the crank is 42 mm in diameter.
any help would be appreciated.
