Banshee big bore kits???
Old Jun 20, 2005 | 04:01 AM
Crashedfast's Avatar
Default Banshee big bore kits???
I want to get a big bore kit for my banshee. I have been looking at the vito 404 kit. Is this a good kit? Is it reliable? How much power? And are there better ones for about the same cost?
Thanks,
Crashedfast
Old Jun 20, 2005 | 06:52 AM
enFORCER's Avatar
Whats in the kit? Is it just big bore sleeves and pistons? You will see a better power increase if you just have your stock cylinders ported, and you install a +4 stroker crank..... Are you running the stock carbs?
Old Jun 20, 2005 | 07:01 AM
enFORCER's Avatar
Do you have an adjustable timing plate or degree key on you banshee???
Perhaps you should tell us a little about your Banshee........
Old Jun 20, 2005 | 03:03 PM
My banshee is a built 350 and i just blew it up again, so instead of just boring it i wanted to get the big bore resleeve kit (big bore sleeves, pistons, gaskets, and wristpin bearings) I have alread had my stock cylnders ported, but now i need to bore it or resleeve it because i just blew up my engine and messed up the cylinder walls. It was running 65 hp. Im not sure if i have the degree key or the timing plate, but i know i have one or the other. A mechanic did all my engine work and im not sure exactly what all was done. I still have the stock carbs but might be getting new ones, if i need them.
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
Alex G.
Sep 16, 2015 12:13 PM
Lou Domenech
Sep 11, 2015 06:35 PM
