Prairie 360 belt light not resetting
Old Jun 26, 2005 | 10:33 AM
MikeRhyne's Avatar
Default Prairie 360 belt light not resetting
Our prairie 360 hit the 100 hour mark and the belt light came on. I can't get it to go off. I can trip it into the reduced power mode and then do the reset process to get it back out of that but the belt light keeps blinking. Any ideas on how to reset that light? The belt switch is not tripped as well as I tried the belt cover from our 700 and that did not help. The process I'm using is to up plug the 2 wire connector to the trip switch and then reverse the black and gray plugs. Then turn the machine on for 30 seconds or so. Then turn it off and return the connectors to normal.
Thanks,
Mike
Old Jun 26, 2005 | 06:22 PM
alwaysride's Avatar
you are correct i think for the most part. Disconnect the 5 pin connectors(as you already have been doing) and put them in their opposite color. There is also a 2 pin connector witch is black right next to the 5 pins. disconnect that and leave it alone. Turn the key on for about 10 seconds and turn it off. put the 5 pin connectors back to their right spot and then the 2 pin back together. There you go. hope this works.
Old Jun 26, 2005 | 06:56 PM
MikeRhyne's Avatar
That is what i'm doing. I have tried every combination that I can think of similar to that as well...
Thanks,
Mike
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Logan Collins
Sep 5, 2015 08:03 PM
Pahuntman
Sep 5, 2015 11:07 AM
