Noisy transmission
Old Jun 27, 2005 | 07:06 PM
pads's Avatar
Default Noisy transmission
I have a 2004 Twin Peaks. When the transmission is in low and I give the throttle "stabs" there is a slight clunking in the transmission around the belt drive area. When I put it in high, there is no noise. Everything was just gone over from the dealer and it runs flawlessly. Is this a normal sound? I had read in some previous posts that the tranny is quite noisy. I don't ever remember there being a sound there before but mabye I just missed it.
Old Jun 28, 2005 | 06:17 AM
pads's Avatar
No one else has this problem?
Old Jun 28, 2005 | 11:54 AM
tuffEnuf's Avatar
Primary does make a clunk noise when belt engages(centrifugal force overcomes primary spring pressure, causing sheeve to close on belt). If your belt deflection is within specs, & all your nuts and bolts are tight/torqued to specs on primary & secondary clutch(s)wouldn't worry.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Jun 28, 2005 | 01:53 PM
BRT's Avatar
BRT
I got an 05 BF 650 that I thought the tranny was noisier than it should be.
Went back to the dealer and rode a couple 700s and another BF around the lot and sounded the same.
I think my problem was me being too worried.
I will have a new HMF pipe by this weekend so I won't hear any strange noises anymore.
Just exhaust and the wind whippin by.
Old Jun 29, 2005 | 06:11 AM
pads's Avatar
Thanks for the replies. I think I'll just ignore it and enjoy it. I also read something about square cut gears that make some noise also.
Old Jun 30, 2005 | 01:59 AM
Kawierider's Avatar
It's normal. This topic has been touched on several times. My Prairie 700 makes a lot of clunky noises when in low-range 4X4. You should hear a V-Force with paddle tires go across hard ground. It sounds like the tranmission is disintegrating.
Jeff Roper
Feb 1, 2022 11:48 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
shimanok2
Jan 29, 2016 07:37 PM
r1pilot83
Sep 27, 2015 07:38 PM
WilliamBos
Sep 22, 2015 04:07 PM
