anyone know how to change a sterring pivot bearing?
Old Jun 28, 2005 | 06:51 PM
300exfreak's Avatar
Default anyone know how to change a sterring pivot bearing?
sure could use some help
Old Jun 28, 2005 | 07:27 PM
quad2xtreme's Avatar
Have you taken the nut off the steering stem and removed the stem?
If so, go down from the top side where the steering pivot bearing is located. There should be a seal. Remove it. Under the seal there should be a circlip (internal c-clip). You have to remove it. Then you tap the bearing out from the bottom of the quad upward.
This is how Honda put it together for the 400ex anyhow. I tried to look at the diagrams at Service Honda. Looks to be about the same except that miss labeled the circlip and called it a cotter pin.
/Jon
Old Jun 28, 2005 | 10:56 PM
TractorPacker's Avatar
Do you have a balloon?
Yes, pull the stem and remove the snap ring. On our 300, the bearing came out by hand.
Old Jun 29, 2005 | 06:57 AM
300exfreak's Avatar
thanks for all the info. so where do you all like to ride?
Ean
Dec 19, 2022 08:48 AM
Cummins Driver
Sep 11, 2019 01:22 PM
Divergent12
Dec 30, 2017 08:33 PM
akbrewcrew
Aug 9, 2015 10:54 PM
Chuck188
Jul 17, 2015 02:45 PM
