Stripped brass screw on float bowl.
Old Jul 4, 2005 | 05:48 PM
azrider25's Avatar
Default Stripped brass screw on float bowl.
Any advice on how to get this thing out?
Old Jul 4, 2005 | 08:42 PM
Al1's Avatar
Al1
Maybe try vise grips(even the needle nose ones) thats what I did if you can get them on the head of the bolt ,then put the allen head bolts in you can buy them at home depot or lowes.
Old Jul 4, 2005 | 08:45 PM
AtvBoy1's Avatar
If your reffering to stripping the slot head out I did the samething on my Rincon. Those soft screws suck. Take a chisel or simliar sharp end object/flathead screw driver. Put it on the side of the screw. Hit it with a hammer and it will break loose. Then get some replacement screws at the hardware store to put back.
Old Jul 4, 2005 | 11:29 PM
sammydogs64's Avatar
They are called "Gas Pump Pliers" I got a set from work years ago and they worked perfect to get the two screws I stripped on my 03 Prairie 650.
Old Jul 5, 2005 | 09:56 AM
777's Avatar
777
needle-nose vise grips
Old Jul 5, 2005 | 10:17 AM
tuffEnuf's Avatar
Best bet is to replace them all with allenhead or torq head .04 X 14mm screws from your local hardware. If you don't you'll have repeat problems down the road.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Jul 5, 2005 | 07:08 PM
azrider25's Avatar
Thanks for the suggestions fellas. I did the chisel/screwdriver trick and that got it out. They have since been replaced by allen heads to avoid this problem in the future.
Old Jul 16, 2005 | 11:58 AM
HappaRap's Avatar
Lazy Boy Rider!
This is a typical problem with most quads, don't know why they don't put allen screws on the bowls in the first place. I took a hacksaw blade to the stripped screw on my rappy, cut a slot and it came right out.
Oct 10, 2015 10:20 AM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
tysonbully
Sep 28, 2015 02:30 AM
wrencher82
Sep 24, 2015 03:39 PM
