will the shocks work
Old Jul 6, 2005 | 12:56 PM
warriorboy22's Avatar
Default will the shocks work
is it possible to put front and rear raptor shocks on my warrior and if so what do i have to do
if the raptor shocks fit how much differently will my rid be
Old Jul 6, 2005 | 02:08 PM
2phast4u's Avatar
i was also wonderin this but w/ aftermarket shocks
Old Jul 6, 2005 | 02:11 PM
Warrior02man's Avatar
any year fronts work. YFZ fronts work also, but u need to cut em down. u need to get an 01 rear for it to fit. if u get a diff year, ull have to cut/shorten ur air box.
Old Jul 6, 2005 | 04:37 PM
heatseeker8's Avatar
Misinformation..you DO NOT need to cut or grind anything down to make a YFZ shock fit a Warrior.
simply loosen the jam nuts all the way to the top and compress the shock with a pry bar and slide the shock into the mount.
Old Jul 7, 2005 | 01:42 PM
so if i was to put raptor shocks all around i will need 01??? will the yfz shocks fit all around
witch would ride better i ride trails but i love to hit jumps
Old Jul 7, 2005 | 04:09 PM
midnite's Avatar
You would be better off getting aftermarket shocks.
Old Jul 7, 2005 | 07:01 PM
why would it be better to buy aftermarket suspension instead of stock raptor or yfz suspension
i dont want to go crazy
Old Jul 7, 2005 | 10:38 PM
Yes. and it hurts when a hammer hits your thumb instead of the nail.
any other brain busters?
Yes YFZ front shocks fit the Warrior with no problem. NO GRINDING REQUIRED.
Old Jul 7, 2005 | 10:53 PM
raptorider660's Avatar
u wouldnt put yfz shocks on anway so wats the point
Old Jul 7, 2005 | 11:01 PM
raptorrider660 i will put what ever i want on my quad.
so the yfz shocks will fit in the rear correct
