KFX-700 Performance Mods
Old Jul 7, 2005 | 02:21 PM
kfxandahemi's Avatar
Default KFX-700 Performance Mods
Hi all new to the forum. I have a 04 KFX-700 with a K&N airfilter and was just curious what would be some other mods that would actually be worth spending money on. I have researched a dual alien exhaust kit. Is this the best one for the KFX or not. Any info or any input would be helpful. Thanks
Old Jul 7, 2005 | 03:36 PM
mojo21's Avatar
Probally any mod to a kfx 700 would be worth it. I know cwr has a 900 BB kit for them which I couldnt imagine the power that thing would have, thier pretty fast the way it is stock. The air filter is good and jet it when you get a pipe, that little bit would be worth the money deffinitly. I'm not to sure about pipes for it probally white bros carbon pros, pro circuit t-4 and the aliens are all decent pipes its just what the kfx responds to better which I dont own one so I would have no clue to which one it likes. Hope this helps out a bit.
Old Jul 7, 2005 | 04:48 PM
enFORCER's Avatar
I have HMF pipe's on my KFX700.... I have heard good things about the Muzzy pipe...
For $20 you can change your primary sping to a EPI pink or a Dalton blue/orange... For a few dollars more you can change the clutch weights and install a Dalton overdrive clutch cover
After you put the pipe's on you will want to open up the air box a bit and rejet the carbs, witch is very easy....
After that you can install a little bit bigger cam...
Advance the timing or install an aftermarket CDI....
Old Feb 15, 2008 | 03:59 AM
stuntman700's Avatar
well i have a kfx 700 with air box mods, DMC ALIEN PIPES(they sound bad azzz like a harley hahaha) jets and itz pretty damn fast and i havent even got the clutch spring wich is almost the first thing u should get haha i messed up not getting it first but anyways
Old Feb 15, 2008 | 04:43 AM
stillV1's Avatar
The KFX really responds well to the Muzzy 2 into 1 exhaust from what I'm told. I am getting ready to do mine. Jetting up and the 12 hole airbox mod will work good with an exhaust and the clutch spring will help by increasing shiftout or adding stall. If drag racing is your thing, then the dalton orange/blue is a good spring. The EPI almond, pink or maroon are also good choices. If you go on kawieriders.com, they say that v-force John does a great stage 2 clutch mod and there are also tons of internal mods as well!
Old Feb 15, 2008 | 10:00 AM
wow... this is an old one dug up... sold that bike 2 years ago lol
Customer Service #1
May 15, 2020 08:46 AM
Sep 30, 2015 01:37 AM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
