Click--Click--Click
Old Jul 7, 2005 | 09:45 PM
400EXerciser's Avatar
Default Click--Click--Click
I tried starting my DS to load it to go riding on this holiday. It started kind of slow but ran good enough to drive up the ramps on the trailer. Got to our riding spot and tried to crank her up and all I got was clicking sound. Tried charging the battery but no luck. All I had was a test light with me and it showed voltage to the starter so I tried to pull start in and could never get it to fire at all. Got back home and charged the battery to 13.4 volts. Tested the starter relay and had only 7 volts leaving to the starter. Is this just the relay going bad or could there be another problem I need to check into. If it is the relay were could I order one from as we do not have any dealers close by. Thanks for any insight you can shed on this.
