Question about smoking exhaust
Old Jul 10, 2005 | 06:03 PM
Taharnak's Avatar
Default Question about smoking exhaust
Ok, I changed the oil again and put in 3/4th of a quart and its at the right level, and I rev it now and it doesnt bog down as bad if hardly at all, and then I started giving it gas to see if it still smoked and it only smokes after I let off the gas and it goes back to idling and it only smokes for about 2 seconds then stops, So basicly I give it gas it doesnt smoke, let off the gas and right when it returns to idling it starts to smoke a little bit. Any ideas whats wrong? Or is this normal?
Old Jul 10, 2005 | 07:01 PM
BuLLFr0G's Avatar
What color is the smoke?Are you on level ground when you check the oil?Are you checking the oil when the motor is hot or cold?Are you sure is stops smoking when you give it gas or you just cant see the smoke when you are giving it gas?
Old Jul 10, 2005 | 07:07 PM
Taharnak's Avatar
the color of the smoke is greyish. The ground is level, Its in my garage lol and the garage is level. I checked the oil when the motor was cold. and im pretty sure it stops smoking when I give it gas, Maybe I just cantt see it. I could see it on the video when I took the video of it yestarday before I did all this.
Old Jul 10, 2005 | 07:38 PM
BuLLFr0G's Avatar
Gasoline Engines
Type of Smoke
Diagnosis
Probable Causes
White
(lasting more than 5 seconds)
Note: If white smoke appears only during the first few seconds of start up, no repair is needed.
Coolant or water leaking into combustion chamber
· Bad head gasket
· Warped or cracked cylinder head
· Cracked block
Blue
Engine oil being burned
· Oil leaking into combustion chamber
· Worn piston rings, valves or cylinders
· Bad exhaust manifold
· Bad head gasket
Black or Gray
Note: If black or gray smoke appears only during the first few seconds of start up, no repair is needed.
Incomplete fuel combustion
· Clogged air filter
· Carburetor, choke, fuel injection or emission system malfunction
· Damaged or worn valve guides
· Low compression due to engine wear
aint I helpful[img]i/expressions/face-icon-small-happy.gif[/img] lol
Old Jul 10, 2005 | 08:46 PM
BuLLFr0G's Avatar
well did I help?Have you tryed looking at the air filter or maby spark plug?
Old Jul 11, 2005 | 02:32 AM
RapDaddy660's Avatar
lol, well that sums it up now dont it!
Old Jul 11, 2005 | 02:50 AM
Taharnak's Avatar
I dont have the .... like... pre-filter or what ever that goes around my K&N filter on. and I checked the plug on the site that has wether it needs to be rejetted or not and it was good. so idk... My carb leaks a little gas when I start it, it pours out the spout at the bottom I think, I might look at it later. Dont really know.. I changed hte oil to the right level and it runs a little better.
Old Jul 11, 2005 | 08:25 PM
BuLLFr0G's Avatar
Your carb shouldnt do that unless you stand the bike straight up on its end.I would know because I
have done it many times when I wasnt trying to.lol [img]i/expressions/face-icon-small-happy.gif[/img] Good times.
Cole Hadden
Jun 15, 2025 09:05 AM
dirt ryder
Sep 27, 2015 09:22 PM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
Dirtbikemike1
10
Jul 12, 2015 07:22 PM
