Prairie 650 - Torque Specs
Old Jul 10, 2005 | 07:14 PM
aachten's Avatar
Default Prairie 650 - Torque Specs
Need torque specs for:
1) Castle nuts on the front suspension knuckle
2) The 27MM Castle nut on drive shaft (hub)
3) A-Arm Bolts
Thanks!
Old Jul 11, 2005 | 06:27 PM
Al1's Avatar
Al1
suspension arm pivot bolts 65ft-lb(where the a arm bolts to the frame)
front axle nut 145 ft-lb(hub)
tie rod end nuts31 ft-lb
steering knuckle joint nut 31 ft-lb(where the ball joint slides into the knuckle)
This is what I found in my manual, I`m not sure if it is exactly what you need.
Old Jul 12, 2005 | 10:06 PM
aachten's Avatar
Thanks for the info. I torqued everything up. I replaced the a-arm bearings and seals and the wheel bearing on the left side. Thats hub nut is one bugger to torque on. Thank god it is done.
Thanks again.
Old Jul 12, 2005 | 10:31 PM
Al1's Avatar
Al1
No problem glad I could help.
ReconBayou
Oct 16, 2019 02:24 AM
dannytas
Sep 26, 2017 06:31 PM
hueby
Nov 6, 2015 11:34 AM
raman8tor
Sep 20, 2015 07:35 AM
PrairieDog126
Sep 12, 2015 05:23 PM
