Backfiring on 400EX after performance upgrades
Old Jul 10, 2005 | 09:43 PM
JBlatch's Avatar
Default Backfiring on 400EX after performance upgrades
I am new to this forum and new to adding performance upgrades to my quad. I recently installed a K&N air filter with an HMF slip exhaust and a Pro Cricuit header and the Dynojet re-jetting kit. I first installed the filter, then the HMF slip on and it ran fine. Then re-jetted it and installed the Pro Circuit header and it started to backfire when I would let off the throttle. The jet size now is a 170 and the needle is at grove number 3. I initially installed the the 146 jet but the a neighbor suggested to go to 170 because of the full exhaust. Just wondering why it is backfiring and if anything can be done about it?
Old Jul 10, 2005 | 09:48 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
is it a stock pilot jet?
did you try increasing the air fuel screw to richen the low end?
Old Jul 10, 2005 | 09:58 PM
JBlatch's Avatar
Tried that but it still continued to backfire and a dumb question. What is the pilot jet. Being that I don't know I am pretty sure it is stock. Just replaced the main jet
Old Jul 11, 2005 | 12:48 AM
hondabuster's Avatar
The pilot jet controls the gas flow in the idle circuit, and it sounds like its too small. Go at least one size bigger, and readjust the mixture screw.
Backfire on letoff is a sure sign of a lean idle circuit, also check for intake leaks, as that could lean out the idle circuit too.
Old Jul 11, 2005 | 02:05 AM
White7's Avatar
yep pilot jet
Old Jul 11, 2005 | 01:09 PM
CassCor's Avatar
JBlatch,
One of the most common causes of backfiring while letting off the throttle is an air leak at the connection between the cylinder head and the exhaust flange. I'm not saying that's definetly your problem, but, its not hard to check it and you haven't lost anything if its not the problem.
HTH
Brian C.
ReconBayou
Oct 31, 2022 05:37 PM
Sep 30, 2015 01:37 AM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
