Bayou Starting Problem
Old Jul 11, 2005 | 06:30 PM
timdog's Avatar
Default Bayou Starting Problem
I have a 1995 Bayou 300 4x4 and went to start it today with no luck. With the key on and in the start position I cannot get the nuetral light to go on, even when its in nuetral and rolls free. Also, I was able to pull start it and get it running for a bit however the carb was gunked up so I had to stop it and pull the carb and clean it. I also put a fresh spark plug in it while I was at it. The battery is charged and I just have no idea what it can be. All of the fluids are fresh as well.
What should I check? I feel the not starting has something to do with the nuetral light not coming on as it will not even crank when i push the START button.
Please, hopefully someone has an answer for me. All comments are greatly appreciated and I hope to hear from you all soon. Thanks.
Old Jul 11, 2005 | 09:52 PM
tuffEnuf's Avatar
Always start with the basics. 1st Get/order you a shop manual.
In interim, check battery state of charge (Voltage), Bulb, fuse(s), fuse holder, and all battery & battery fuse, connections, and grounds.
Try holding the brake lever(s) & see if it makes a difference
Check Fuel petcock, flush old gas, & ensure FRESH fuel is flowing in the run & reserve position. Check/clean your airfilter. Spray a couple bursts of Either in airbox, Full choke it & try starting. Once you get it started, warmed up, choke off, Rev it up 3/4 throttle and spray 1/4 can Carbureator cleaner through carb.
1 drop of water in the bowl, gummed up main and or pilot jet will prevent it from starting. Some bikes also have a neutral safety switch, shop manual will tell you.
Happy trails.[img]i/expressions/face-icon-small-cool.gif[/img]
rcappie4
Jun 21, 2015 07:33 PM
jgreerberube
Jun 21, 2015 02:27 PM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
momofo
May 27, 2015 12:06 PM
