Is a 48 to big for trails
Old Jul 14, 2005 | 10:01 PM
stockbomb's Avatar
Default Is a 48 to big for trails
I am going to get a new carb and do lots of trail riding, is a 48 to much? The shop that did my head work said it will handle a 48 easily, but how would it work in the trails?
Old Jul 14, 2005 | 10:17 PM
Sandaholic's Avatar
Tell us more about your engine. What cams, what size valves? I assume the head is ported. What compression? Stock bore?
What kind of trails are you talking? Wide open fire roads or tight technical woods? If all you do is technical trail ride and don't open it up much I would think the 48hv is too much, the 46hv may not be the best either.
When I had my 46hv, it worked fine on the slow stuff, but it really shinned when you opened it up in the dunes.
Old Jul 14, 2005 | 10:21 PM
stockbomb's Avatar
I have a stock bore 14:1 piston, web 109 cams, ported head and intake, 1mm. over intake valves, rwr CDI box, stock exhaust with end cap, and a couple stickers.
Old Jul 14, 2005 | 10:28 PM
OregonDunePatrol's Avatar
Send a PM to thumper650, he just got his TM48 installed two days ago and went for a ride already. He's pretty much stock with a MSD Ignition and a pipe. He rides trails.
Old Jul 14, 2005 | 10:54 PM
shmee's Avatar
the 48 wont feel any diff than the 45, until ya open it up[img]i/expressions/face-icon-small-wink.gif[/img]
it will be fine. make shure the acc pump is working!
Old Jul 14, 2005 | 11:14 PM
crazypainter's Avatar
Just get the pull lightened up to save thumb fatigue and get it tuned properly and its no worse than any other aftermarket carb.
Old Jul 15, 2005 | 12:24 AM
shmee's Avatar
send it to hightower he will fix ya up with the thumb pull[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 15, 2005 | 01:51 AM
thumper650's Avatar
ya i got mine and shi* the is the best mod ever. im all stock only a MSD and Pipe. I do alot of trail ride i went yesterday and lets just say i went in to a bush cuz i did a 180 it was fun. Ya in a month or 2 im gettin a HPR800 kit and thats why i need a TM48. I would buy any thing form OregonDunePatrol(On Dunes). he treats u right and he gets it to asap.
Old Jul 15, 2005 | 05:53 PM
stockbomb's Avatar
Does anyone know whwre I should start at with jetting? I'm at a 170 main right now in the stock carb if that helps.
Old Jul 15, 2005 | 06:51 PM
H's Avatar
H
Dyno tune. Worth every cent.
