Tips on racing
Its easy to hit turns hard, all you do is get into a gear that you can spin the tires in and kick the bike out sideways. All you do is a powerslide and if you can do that you should be fine. For jumps now, the best thing you can do is start off by hitting jumps and not trying to clear them the first time. Land in the middle, that way you can get an idea of how much faster you need to go. This will help your timing. And as soon as you get your timing down on all the jumps go around your track or whatever you have and just get used to hitting all the different jumps one after another that way you can be more comfortable with your bike and know in general how fast you will have to go for any other jumps you run in to on a track you dont know
