Ron Wood Drag Pipe
Old Jul 17, 2005 | 12:23 PM
OregonDunePatrol's Avatar
Default Ron Wood Drag Pipe
For those considering the Drag Pipe for the DS from Ron Wood, the rubber mid-pipe mount they have will not hold the drag exhaust since there is no exhaust can mount. I've given information to the solution to this problem to TheBOM - Since he did most of the work on the Drag Pipe design. I thought that was the correct thing to do.
Old Jul 17, 2005 | 05:56 PM
Eaglecollector's Avatar
So does that mean the heavy dudy mount you offfer on your site is no longer any good and no longer for sale?
Old Jul 17, 2005 | 05:59 PM
The mount, and the solution I gave to theBOM is exactly the same.
Old Jul 17, 2005 | 06:02 PM
Good deal Marky...I was just there looking at some pipe options and came accross that mount. And then read your post. lol
Old Jul 17, 2005 | 07:01 PM
MrMeaner's Avatar
I used an aluminum spacer and Ive had no problems
Old Jul 17, 2005 | 08:43 PM
There's nothing wrong with a hard aluminum spacer. I've used that before too. The rubber mount just takes some of the vibration out of the exhaust. Plus, with a rubber mount you'll get some give from the mount. I've broke about 4 bolts on a hard aluminum mount mount over the years. A good rubber mount is little better. With the pipe expanding and contracting, you'll put a lot of stress on a bolt and hard spacer. Like I've said, I've used both.
Old Jul 18, 2005 | 01:47 PM
Hightower's Avatar
another point - if your RWR exhaust has been on the bike for a good while, make sure you can get the tailpipe seperated from the headpipe before you order a drag can. they may be rusted together, and it may be a bigger job than you think getting them apart. DSBOMB tried putting the drag pipe on at St. A's a couple weeks ago, he could not get his old RWR muffler seperated, I think the only way is to put some torch heat to it, but not everybody has a torch out in the desert.
yet another reason why I will never again own anything that is not stainless.
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
greg86hd
Sep 16, 2015 12:32 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
