blew my banshee
Old Jul 18, 2005 | 10:58 PM
Dml39's Avatar
Default blew my banshee
earlier 2day i blew only one cylinder in my banshee it still runs and drives but only on one side of the engine the other exhaust jus backfires and its got no power almost now but i was just wonderin is it ok to just have on side of the top end rebuilt or is this bad to do ?
Old Jul 18, 2005 | 11:06 PM
warriorboy22's Avatar
i would do both this way the engine wears evenly
Old Jul 18, 2005 | 11:39 PM
Storj's Avatar
it depends if you seized it and the pistion didnt scratch the cylinder then just flush it out and pop a new piston in but if it was scored then i would definatly get both done so that its balenced. and runs correctly.
Old Jul 18, 2005 | 11:47 PM
Six2notScaredofU's Avatar
Are you Sure You Blew one Side? Mine did that once and it was just a Fouled Plug. Just Something to Check.
Old Jul 18, 2005 | 11:50 PM
Dml39's Avatar
no i put in a newer plug and it was still not firin properly and it has barely ne to no compression in that side
Old Jul 19, 2005 | 12:25 AM
NBake's Avatar
i would take the head off and check the cylinder walls. like storj said as long as u didnt score the wall, u can jus put in a new piston and rings and be good to go. if u checked the compression i assume its not seized, so if the compression is low then the rings r worn. do u remember what the old plug looked like when u replaced it with the new one?
Old Jul 19, 2005 | 02:12 AM
fasterthanyou22's Avatar
lol....I would just make the investment for the banshee hemi head.Sooooooo much more power and more reliable.....I am pretty sure it is a bolt on head.It is no more that 600 bucks i think.Hmmm.....i think....oh well.....And it isnt going to scratch the cylinder walls, all you have to do is get a new piston and a SLEEVE if the SLEEVE is scratched.But i would still get the hemi head.....He he he...[img]i/expressions/face-icon-small-cool.gif[/img]
Old Jul 19, 2005 | 06:11 AM
atvbandit's Avatar
sounds like you need a top end rebuild but before you do anything, you need to find out and correct the problem of why that particular cylinder blew. also you need to do both cylinders for even compression
Old Jul 19, 2005 | 03:17 PM
Storj's Avatar
you may have just blown a gasket or something pull the head and check it out
Old Jul 19, 2005 | 03:36 PM
ltdbanshee03's Avatar
from what your saying you definentily blew it up. the less your ride it the better so id say to just get that thing to a shop and fixed. make sure your not getting ripped off for the work.
ReconBayou
Oct 31, 2022 05:37 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Jul 7, 2015 11:00 PM
