Cant decide Banshee or Lt500!!!
well, look at it this way...the banshee will go real fast in a straight line, and when you hit the turn, throw you off if your not carefull, the lt500 will go real fast in a straight line, and break before you get to the turn. Go with the banshee, more aftermarket, better resale
ur gonna have problems with a quad made 15 or more years ago. the only problems i had with mine in the past year and a half was a bad pulse coil and the original flywheel. after that no problems since, so shut ur mouth. anyway both machines arent good choices for the woods, the banshee for its lack of low end power and suspension, and the quadzilla for its size. the quadzilla has power everywhere with torque like a 4 stroke. the banshee has a powerband like a 125 dirtbike, all in the upper mid range to top end. the quadzilla is a lot wide and longer, making it more stable. the banshee is more nimble. for the wide open spaces (where they both work the best) id take the stability and power of the big lt.
