102mm Gaskets on stock bore cylinder ?? (Raptor)
Old Jul 25, 2005 | 08:52 PM
wshrdskin's Avatar
Default 102mm Gaskets on stock bore cylinder ??
There shouldn't be any problems useing 102mm base and head gaskets on a stock bore cylinder right?? TIA
Old Jul 25, 2005 | 11:18 PM
wshrdskin's Avatar
Default 102mm Gaskets on stock bore cylinder ?? (Raptor)
Bumpity bump, bump, bump [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 26, 2005 | 12:30 AM
XR650Warrior's Avatar
will probably get you up and going, but the proper sized gaskets are no more than 30 or 40 bucks, why mess with it for that amount of $
Old Jul 26, 2005 | 01:40 AM
quicksilver's Avatar
whats the stock bore? 100mm? if so, I would try to avoid it. THe metal sealing ring on the gasket wont be in the right spot and the top edge of your cylinder will be away from the ring, and the edge could get red-hot since the ring is too far away to absorb the heat, so you could get some nasty pinging action going on. Trust me, I'm an auto technician and i remember this topic in school. Go with the correct gaskets, you could wreck your engine if you go with the oversized ones.
Old Jul 26, 2005 | 01:21 PM
Chimmer's Avatar
102mm Cometic would work ok for 100mm stock bore but I would use OEM 100mm if I had the choice. I've used 102mm Cometics for 101mm bores with no problem at all.
Old Jul 26, 2005 | 02:22 PM
MasterRaptor's Avatar
Standard Cometics work for 100mm - 102mm bores.
Old Jul 26, 2005 | 09:08 PM
wshrdskin's Avatar
What I have are Cometic 102 mm base and head gaskets. I have a couple sets and would use one of them in place of the OEM if there will be no issues.
Firefighter400
Oct 8, 2022 06:38 PM
STLyamwar
Jul 25, 2020 04:44 AM
Asaran
Oct 8, 2015 11:14 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
