I need help splitting the case on my blaster.
I was wondering if any of you had replaced the crank in a blaster. I have a clymers manual and have followed every step but im stuck. I can't get the case to come of evenly. I have the puller and when I try to split the case the right side of the case comes up but the left side moves very little. My dad and I checked and all the bolts and gears are taken off. I re-read the manual and double checked everything. Anyone else have this problem? Any tips?
Thanks for the help
Nez
Thanks for the help
Nez
When I split the case on my YZ125, I just wiggled it bask and forth to get the halves apart(move apart the right, then the left, then the right, then the left). The cases should slowly move further and further apart. If that doesn't work, you can gently pry the cases apart with a piece of wood, or some other material that will not harm the cases or gasket surfaces(use common sense here). My dad used a crowbar, but this is definately not recommended.
Hey thanks alot. I got it apart today. Patience seemed to be the key. Now I have to figure out how to get the crank back it without the tool.
Thanks alot
Nez
Thanks alot
Nez
