pure sport bandits
If you can wear a set of bandits out you are truly a atv rider. Traction is OK but these tires are way heavier than the mx tires like holeshots. If you xc race and dont ever want to worry about flats or punctures then you cant go wrong with bandits. Even if they loose all thier air you can still drive on them and make it back home. Im talking the bandit rear xc.
They're heavy, so make sure your ATV has enough power to turn them; an open class ATV would be best. Forward traction is equal to, or better, than Holeshots or Razr's. Sliding traction is not as good, and the rear end can tend to step out on you more than you want it to. Braking traction is not as good either, and they can tend to fishtail a bit under long hard braking, such as a panic stop from 70+ mph. They are bulletproof though, and I have been running them all year long desert racing. So far they have done six desert races with no flats, and other than the initial rounding off of the knobbie edges I cannot tell that they have worn at all.
DV
DV
